Stephens Web Site
Date:  3-26-2016
Manual Reference:  Section 7
Brief Description:  Finish Riveting Ribs on Right Tank
Kevin came by and helped buck the last few rivets at the leading edge of the tank. I drilled and removed two bad rivets from my solo riveting and then we started. We did rivets on top and bottom of tank and also finished the last rib. All rivets set using wet riveting method and excess sealant used to cover more shop heads.
Kevin helping
Kevin helping
Sealing shop heads
Sealing shop heads
One rib done
One rib done
