Stephens Web Site
Date:  6-21-2015
Number of Hours:  3.00
Manual Reference:  Section 7
Brief Description:  Prepare Left T-405 Bracket
Laid out the shape of the T-405 the bracket for the left tank root rib. Drilled 1/4 inch holes in the corners of the bracket to make the radii depicted on the plans. Used the band saw to rough out the part. Began working to final shape with the disk/belt sander.
Angle stock to make the T-405
Rough cut
Rough cut
Sanding to shape
Sanding to shape
