I finished fluting the ribs and went back to check all flanges were still at 90 degrees. Had to bend several areas back to 90 with the seaming pliers as I moved the flanges off square when fluting. I removed the blue plastic from all rivet lines on the inside of the skin with the yardstick and soldering iron.
