Began the process to re-make T-712 Z-bracket 1 - 5 to correct edge distance issue with the first attempt. I edge finshed the parts, marked the centerline and exact center of the flange. I moved the center 1/32 inch toward the flange, centerpunched and drilled to #40. Then followed up with a #12 to drill to full size. Deburred all holes.
