Stephens Web Site
Date:  2-2-2015
Manual Reference:  Section 7
Brief Description:  Left Outboard Leading Edge
I fluted the ribs for the left leading edge and re-marked each rib to be sure I could get them in the correct order later. I put each rib in with one cleco from the inside on the bottom side, forward most hole. I worked on the bench after reading several opinions on ease of assembly on the bench vs. in the cradle. I was able to press the skin down onto the top of the ribs enoungh to get a tapered alignment punch into a skin and rib hole. I used the punch to hold the skin while inserting a cleco, then worked a couple of more cleco's into the top of the rib. Repeated this process to get all four main ribs cleco'd on the top. Flipped the piece over, inserted a cleco in the bottom of each rib, then moved the inside cleco to outside and finished clecoing the bottom of the skin. Inserted the W-709R end rib and cleco'd it. The inboard rib is not drilled so I held it in place and used the skin holes to make reference marks with a Sharpie, then fluted this rib between the Sharpie marks. My skin fit the ribs well, with not much effort required to get everything lined up and cleco'd.
Leading edge cleco'd
Ribs fit well
Ribs fit well
Top view
Top view
