Match drilled the forward end of the right and left wing ribs using the main spar as the drill guide. Tipped each wing to horizontal to facilitate drilling aft end of ribs using rear spar as the drill guide. Frances helped with lifing the wings and steadying while I drilled and moved cleco's. The rolling wing stand was great here as we did the left wing then rolled it out of the way to drill the right wing in the fixed stand. Thanks to Steve Soloman, Chapter 339, for the rolling wing stand.
Once both wings were match drilled, I began disassembling, deburring the holes, and prepping for primer.
