Deburred the conduit holes in the ribs for the right wing. Made a piece of angle aluminum to support tip end of spar. Drilled, deburred and mounted angle to tip rib with 1/4 inch nuts and screws.
Cleco'd all ribs to spar. Double checked for correct order. Cleco'd on the rear spar. Numbered all ribs to help with re-assembly later.
