Brief Description: Center Section Attach Nutplates
Back from Oshkosh and eager to get to work. Drilled and deburred the rivet holes for the center section attach nutplates. Made certain the orientation of the spar before countersinking the aft side of the spar for the rivet heads. Cleco'd the nutplates on and riveted usng the squeezer with a 4 inch no-hole yoke I borrowed from Kent. Jason helped hold the spar and make certain the squeezer was flush on the back side. Both wing spars are complete.
