Stephens Web Site
Date:  7-14-2014
Number of Hours:  1.00
Manual Reference:  Section 7
Brief Description:  Left Spar Inspection Plate Nutplates
Began work on mounting the inspection plate nutplates on the left spar. We drilled and deburred the mounting holes, then countersunk with the #40 bit. Set rivets with the squeezer. As I worked on the nutplates, Jason began edge finishing the inspection plates. He filed the burrs, cleaned the edge and finished on the scotchbrite wheel. We will mount the nutplates on the right spar before we change the depth on the #40 countersink to do the screw holes.
First nutplate installed
Back side
Back side
Jason edge finishing
