Brief Description: Finish Fuel Tank Nutplates Right Spar
Continued work on right wing spar to mount the fuel tank attachment nutplates. We drilled and countersunk the mounting holes. Jason deburred holes. We mounted the nutplates and used the hand squeezer to set the rivets. I countersunk the screw holes using the same technique of a slow, high pressure start and finishing with low pressure on the drill and high speed as the countersink bit centered in the nutplate.
