Stephens Web Site
Date:  6-22-2023
Number of Hours:  3.00
Manual Reference:  Section 7
Brief Description:  Install ElevatorTrim Actuator
I cut the threaded rod to size and assembled the components to connect the trim motor to the tab. I found the fitting on the trim motor would hit the skin of the elevator near full travel. Filed the opening and that helped some as I ran the trim through full range of motion. Once I got the fitting to clear, the threaded rod began to drag on the skin. Researched Van's and talked to Ken and both recommended putting a slight bend in the rod for clearance. This worked well and I was able to get full travel on the trim tab with no interference. Drilled a hole for safety wire, bent the end of the hinge pin, and saftied the trim tab hinge pin in place.
Cut the threaded rod
Test travel
Test travel
Final solution
Final solution
