Assembled the elevator and cleco'd it together to test fit the fiberglass tip. I marked the cut out for the counterweight as indcated on the plans, drilled the corners and cut out the pieces with the dremel. I then mounted the dremel on a 2x4 to trim the fiberglass mounting flange to length. I measured the space from the rib to the end of the skin, marked the tip and used the dremel to cut off the edge. Some sanding and filing on the flange as well as the trailing edge, and several test fits later, the tip fits nicely along the edge of the skin.
