Cleco'd on the left and right skins to the rudder skeleton. Fit the trailing edge wedge and cleco'd in place. Drilled all the holes in the rudder skins and skeleton to final size. Trimmed the R-710 rudder brace with a dremel cut-off wheel to rough size, then filed to final size and cleaned all edges with scotchbrite wheel. Fit the brace to the rudder and match drilled the mounting holes.
