Stephens Web Site
Date:  1-13-2013
Number of Hours:  3.00
Manual Reference:  Section 6
Brief Description:  Begin Front Spar Assembly
Cleco the reinforcing angles to the spar. Match drilled the inboard holes. Also did the layout of the trimming required on the angles. Marked the spars for trimming. Drilled the holes and then trimmed the spar flange with a dremel cut-off wheel. Filed, sanded and finished all the edges to prepare for bending.
Spar with reinforcing angles
Spar marked and drilled.
Finishing the edges
Finishing the edges
