Cleco the reinforcing angles to the spar. Match drilled the inboard holes. Also did the layout of the trimming required on the angles. Marked the spars for trimming. Drilled the holes and then trimmed the spar flange with a dremel cut-off wheel. Filed, sanded and finished all the edges to prepare for bending.
