Stephens Web Site
Date:  1-6-2013
Number of Hours:  3.00
Manual Reference:  Section 6
Brief Description:  Build HS-411 assembly
Set up the HS-411 brackets on a jig and match drilled. Put in the bearing and ran the drill through again. Test fit the assembly in the spar. Then deburred all the holes on both sides. Primed the bearing with NAPA 7220 self etching primer. Reassembled and set the first rivet in the airpane.
Match drilling 411
Match drilling 411
Test fit
Test fit
The First Rivet
The First Rivet
