I had previously drilled a 1/2 inch hole in the bottom of the fuselage for the flap actuator pushrod. This hole has to be connected to a hole in the side of the fuselage. Drilled a hole in the pre-cut location for the actuator and used the dremel to connect the two holes. Repeated on the left side. Will enlarge these holes after wings are installed.
