Brief Description: Finish Drilling Engine Mount to Firewall
Used the same process to drill the lower outboard holes for the engine mount. These tubes were longer so I had to start holes and remove the mount to drill all the way through the structure for the smaller drill bits. Final size was drilled with the mount in place.
