Stephens Web Site
Date:  10-17-2023
Manual Reference:  Section 8
Brief Description:  Prepare Fuel Line Doubler
Back to the project after a break when we had all the kids here. The firewall doubler for the fuel line overlaps the mount for the starter contactor. Marked a minimum edge distance on the rivet hole in that corner, then began working a notch in the corner to clear the mount and not violate edge distance. Several trial and error iterations and I had a notch that worked. I countersunk the rivet holes then scuffed the fuel line doubler, washer, and contactor doubler for priming. Washed and dried parts, then primed with NAPA 7220.
Notch fuel line doubler
Scuff for primer
Scuff for primer
Primed parts
Primed parts
