Made the F-7127D doubler for mounting the contactors per the plans. Used nutplate cleco'd to firewall as drill guide and drilled firewall for mounting bolt. Bolted and cleco'd nutplates to drill second rivet hole. Deburred all holes and used the gun to rivet first two nutplates on. Inserted mounting bolts to check fit and determine overlap on contactor mounting tabs.
