Stephens Web Site
Date:  7-11-2023
Number of Hours:  3.00
Manual Reference:  Section 8
Brief Description:  F-6119 and Rudder Blocks
Began to make the F-6119 rudder cable links using my rough dimension from the safety wire. Made the left links and drilled one end per the plans. Repeated for the right links. Removed the rudder pedal mounting blocks and cut them in half to ease moving them if necessary later in the project. Reassembled the blocks and used washers to account for saw kerf. Found the written plans and drawings had different dimensions for the rudder rod end bearings. Measured mine and found that after rudder fitting attempts mine were now different than both.
Begin F-6119 fab
Begin F-6119 fab
Cut rudder pedal mounts
Measurement comparison
