Put the canopy back on the fuselage and set up to drill new anchor blocks. Marked the compound angles on the right block and set up the drill press to drill the hole. Hole came out well, then I tried to match drill the block to the existing holes in the C-677 brackets. Missed first attempt and egged out one hole. Ordered two new C-677 from Van's.
