Marked locations for Supertracks and checked alignment per instructions. Found the roller would hit the rear blocks a bit on opening. Rounded off forward edge of blocks to eliminate problem.
Shifted attention to mounting the slide rail. Drilled holes in rail and fuselage up to full size for screws.
