More work on bending the forward bow. Used blocks screwed to the bench to work the curve of the bow. Had to reposition blocks a couple of times to get bending where I wanted it. Did a few trial fits and it is improving, still not there yet.
Took a break from bending and used some plastic tubing to protect the stainless brakelines from rubbing on the rudder pedal supports and each other. Slit the tubing in a spiral fashion and it holds itself on the lines very well. Still thinking about how to secure the lines from the left brakes to the firewall. Have a twist tie on them now as a place holder.
