Brief Description: Drill Initial Holes for Rollbar
Received the new stainless steel brake lines and put them in for a test fit.
Continued with roll bar install I measured and marked location of the longeron, then measured and marked hole location for roll bar mounting bolts. From the marks it appears I will have sufficient clearance from the longeron when the holes are full size. Drilled the holes #40 and visual inspection shows I'm too close to the longeron on a couple of holes. Will move these a bit before drilling larger. Made the four C-668 spacers per the plans. Used #40 reamer to elongate the mounting holes slightly away from the longeron.
