Stephens Web Site
Date:  3-17-2022
Number of Hours:  4.00
Manual Reference:  Section 8
Brief Description:  Right Fuel Line and Fuel Pump Line
The fit issues under the doghouse led me to redesign the path for the right fuel line. Decided to include a 90 degree fitting on the valve to move line away from the fuel pump output line. This path worked well and I successfuly completed the right fuel line. Made new connector for fuel filter to fuel pump. Nice smooth curves and it fits under the doghouse. Started new tube for fuel valve to fuel filter inlet, but geometry and bend radius are causing a problem with fit.
New right fuel line routing
Right fuel line done
New connection for fuel pump
