Removed the doghouse and center cover then drilled screw holes to final size. Also drilled the floor stiffener holes to final size. Dis assembled doghouse and drilled for nutplates. Deburrred all holes. Used squeezer to dimple thin material for rivets, countersunk the fuel pump base for "oops" rivets. Washed parts to prepare for primer.
