Useed a soldering iron to make a hole in the conduit in left wing and pulled the wire for the stall warner through to wing root. Used the fish tape to pull strings throught the wing conduits. Disassembled the flap housing and other forward fuselage parts to prep for final paint. Wet sanded the parts with 400 grit. Washed parts in Dawn dish soap and warm water, then set out to air dry.
