Brief Description: Trim F-760 L & R, Drill F-767 Angle
Used the Anti-splat cap for the flap motor assembly to estimate the cut line for the F-760s. Cut the ends of the F-760s with straight snips, deburred, and rounded edges. Took a couple of more trial and error cuts before I was satisfied with the fit. Deburred and rounded corners on the final cut.
Used the cap to mark location of holes in the F-767 angle. Drilled with #40, checked the fit, then drilled up to #30.
