Brief Description: Rivet F-635 Bellcrank and F-695 Gussets
Used the squeezer to rivet the F-635 bellcrank components together. Cleco'd on the left and right F-695 gussets. Was able to use the squeezer to set most of the rivets. Used a gun and bucking bar on the ones I couldn't reach. One bad rivet on right side that I drilled and replaced.
