Spent some time rearranging the supports under the fuselage to prepare for F-770 installation. Put a support at the F-704, one aft of F-707, and one at the tail, as described in Wirejock's build log. Slow process as I was working alone. Attached the side skins to the F-704 and F-705 bulkheads with no problem. They do not line up at all with F-706, about 3/4 inch off at the longerons. Moved tail down as plans suggested and improved, but will need a helper to get the line up close enough to cleco.
Frances helped to push the tail but we are still way off on the alignment. Frustrating. Will sleep on it and try again tomorrow.
