Used the drill jig to drill mounting holes for platenuts in baggage area. Deburred all holes and used the squeezer to dimple the rivet holes and screw holes as I will be using countersunk screws to keep the baggage floor flat. Dimpled two lug platnuts and prepped with a tap. Used the squeezer to rivet them on. Used the deburring tool to make shallow countersinks required for the 1097 rivets for the single lug platenuts.
