I did some research on VAF website on preparing the F-715 ribs for installation. I put the rib in the skeleton and used light shining through the pre-punched holes to mark the hole locations on the web of the rib. Removed the rib and used a square to transfer the marks to the flange. This provides reference for hole locations when fluting to match the curve of the fuselage side.
Drilled the open holes on the skin. I marked each row as I drilled to be sure I got them all. Then moved all the clecos one position over to prep for drilling the remaining holes.
