Brief Description: Cleco Seat Ribs in Center Fuselage
Edge finished the F-715 ribs. Elected not to install the nutplates on the seat ribs as called out in the plans. Will delay and put those on after I prime the ribs.
Cleco'd the seat ribs to the rear half of the F-704 senter section. Double checked plans to be sure they were all in the right place, then marked ribs and location on the center section to help reinstall later.
Began prep on the baggage ribs, remove plastic and edge finish.
