Modified two more F-716 ribs for control clearance per the plans. Same technique as before, used the hole saw to cut the hole, layout cut lines, and cut with dremel. Deburr cuts and edge finish enire rib, repeat.
Started to edge finish the next two ribs, no modifications required to these.
