Stephens Web Site
Date:  2-18-2020
Manual Reference:  Section 8
Brief Description:  Continue Riveting Aft Fuselage
Got the Cherry Max CS3212-4-2 rivets and turned the fuselage over to work. Drilled the bad holes to #30, used the countersink to clean up the dimples so the new rivets would sit flush. Used the rivet puller to install, all four went well.
Turned the fuselage back over and continued with back riveting the bulkheads to the bottom skin.
Pulled rivets
Pulled rivets
Frances ready to buck rivets
Bulkheads riveted to bottom skin
