Got the Cherry Max CS3212-4-2 rivets and turned the fuselage over to work. Drilled the bad holes to #30, used the countersink to clean up the dimples so the new rivets would sit flush. Used the rivet puller to install, all four went well.
Turned the fuselage back over and continued with back riveting the bulkheads to the bottom skin.
