Stephens Web Site
Date:  11-23-2019
Manual Reference:  Section 8
Brief Description:  Add Rivet Holes, Roll Tailcone
Researched the minimum distance between rivets and found we had plenty of space to add a rivet on either side of the figure 8 hole. Also found one hole in the upper J-channel that was oval, and decided to add rivets here, too. Used the rivet fan to evenly space the new rivets on either side of the pre-punched holes.
Stiil working to get all the holes to line up in the tail. DIs-assembled and tried to adjust the curve once more with the bending rig on the bench.
Rivet fan spacing
Rivet fan spacing
Added holes
Added holes
Roll tailcone
Roll tailcone
