Stephens Web Site
Date:  6-9-2019
Manual Reference:  Section 8
Brief Description:  Finish One End of J-channel
I marked the end of a J-channel for the angle cut as decribed in the plans. Drilled at the intersection and used dremel with cut-off wheel to trim. Used files to make cuts final size and round off corners. Finished end with emory cloth and scotchbrite. Repeated process for the remaining J-channels, making sure to make one of each size a left and a right.
Mark and drill
Mark and drill
Trim with dremel
Trim with dremel
Finished sets
Finished sets
