Used the squeezer to rivet the F-707 together. Was about to rivet F-708 when I sawI had not drilled the recommended holes for securing the static line aroud the bulkhead. Measured and marked per the plans. Drilled and de-burred all the holes. Touched up the primer. Riveted the two halves together with the squeezer.
