Stephens Web Site
Date:  3-10-2019
Manual Reference:  Section 8
Brief Description:  Begin Assembly F-706 Bulkhead
Riveted the F-729A and B together with the squeezer. Began assembly of the F-706 center section and realized there was interference on the F-729 with rivets to be installed later holding floor ribs. Used a rivet to mark area to be removed. Checked all holes for edge distance. Used a dremel to gradually remove material until the rivet fit in the cut-out. Also had to remove some materal from the F-730 plate. Touched up the primer once modifications were done.
Rivet F-729A and B
Rivet F-729A and B
Rivet interference
Rivet interference
Cut outs complete
Cut outs complete
