Stephens Web Site
Date:  1-1-2019
Manual Reference:  Section 8
Brief Description:  Assemble F-704 Bulkhead
Finished installing the cover support ribs. Lined up the two halves and cleco'd the spacer blocks in place then drilled them for bolts at the top and bottom. Assembled the halves with spacers and bolts. Used hardware store bolts through the wood spacer blocks. Cleco'd on the end plates.
Began prepwork for F-705 bulkhead.
Spacer blocks drilled
Assembled bulkhead with bolts and clecos
Begin next bulkhead
Begin next bulkhead
