Stephens Web Site
Date:  8-7-2026
Number of Hours:  2.50
Brief Description:  Prep Cross Brace/Begin Red Cube
To prepare for re-installing the SuperTracks and cockpit cross brace I re-painted part of the baggage area than was scratched removing and re-installing the cross brace earlier in construction. I scuffed the area with scotchbrite to get a good surface for paint. Washed with water and masked off the area. Shot with Rustoleum Smoke Grey.
Decided on location for the red cube. Tried several combinations of fittings on the cube, decided on 45 degree on the inlet side and straight on the outlet. Used some plastic tubing to measure the hose lengths. I'll order a custom hose for the inlet, will re-use the original fuel line from Van's for the outlet to the fuel servo.
Prep for paint
Prep for paint
Red Cube location
Red Cube location
Measure hose runs
Measure hose runs
