I decided to re-route the power wire to the fuel pump so I could use the top (larger) snap rings forward of the spar for antenna cables. Disconnected power to the pump and ran it through the middle snap rings then used lacing tape to resecure the fuel pump wires. Made two labels for all the cables with heat shrink and put them on each end. Watched Stein video and did a practice terminal on the coax to refresh my memory on the procedure. Then put connectors on the antenna end of each cable and connected them.
