I mounted the Comm, ADSB and XPDR antennas on the fuselage. Began running wire for Comm antenna. Routed it down the left side of fuselage using Adel clamps on the nutplates I installed for the conduit with main wire bundle. Got the basic length required then cut off wire and ran the antenna wire down to the ADSB antenna but left it long. Will finalize the routing then cut it off and use remainder for the XPDR antenna.
