Brief Description: Dimple Fuselage for Doublers/Prime
Frances came out and helped dimple the fuselage for the doublers. We used a pulled close-quarters dimple die with Frances on the inside and me on the outside with the puller. This worked well. Then I dimpled the ADSB doubler with the squeezer. Masked off the Alodined areas and touched up the primer around the antenna mounts.
