Started on the battery box by laying out the locations for the lightening holes on the front. Used a silver sharpie to mark on the black surface. Drilled a pilot hole at the center and clamped a block of wood under the hole location. Then used a hole saw and electric drill to cut the hole. Repeated for the other three holes, then deburred all holes. Repeated the process on the back until all holes were done and deburred.
