Brief Description: Adjust Pushrod, Make New Aft Blocks
Made a few more attempts to adjust the canopy frame. Succeeded in bending enough so the aft blocks are no longer correct. Got some material from Ken and made new blocks to compensate for canopy bending. Still not satisfied with canopy closing.
Adjusted the F-665 pushrod to make the sticks parallel. The rod ends are both right hand thread so rolling the pushrod does not change the length, just screws one end in and the other out. Had to remove one end from the WD-611 control stick fitting and turn each rod end bearing to adjust, then reassemble with all the spacing washers.
