Got the canopy centered on the frame and clamped in place. I measured the forward posts and the aft frame at the pins and compared these numbers to the fuselage. Measurements match up, so I'm pretty confident the frame is bent to the proper size. Frame is quite high compared to the roll bar, so I cut 3/16" off the ends with a dremel cut off wheel and dressed ends with file. Test fit shows bow is closer, but I will not cut any more until after the canopy is Sikaflexed to the frame.
