Aft canopy frame is still a bit too wide. Tried another technique using a rope to pull corners in. Measured afer each time winding up the rope and made some more progress toward correct width.
The work table is too narrow to hold the canopy bubble so I took a sheet of pegboard I had and screwed it to the work surface to make it wider.
